Unity 4.2 off-box store
Nov 14th, 2007
I am installing a non-failover configuration with two 7845s, one for off-box store and one for Unity - VM only. I have not been able to locate any specific instructions on how the off-box store should be configured (as far as the mail stores). Should it be loaded like a standard Unity server (but without Unity) or are there specific instructions?
ranpierce Wed, 11/14/2007 - 07:39
The installation guide I believe is tbe same guide, what version are you and I will post a link.
Off box you install everything except the exchange part is only the system tools. When installing Unity you need to point Unity to the correct message store which will not be itself.
This is all in the installtion guide.
