Frame-relay trafficshaping
Nov 14th, 2007
Just need a little clarification on the doubt that I have with FRTS.
1. Do we enable " frame-relay traffic shaping )under the FR interface only with legacy FRTS config.
2. With MQC FRTS we dont need the "frame-relay traffic shaping command" under the FR interface.
I think the answer is correct for both the questions, just need suggestion on that.
-amit singh
Overall Rating: 5 (1 ratings)
Amit Singh Wed, 11/14/2007 - 07:04
Thanks Guys.. Got the answer for that. Yes, its true for both the questions.
" Configuring traffic shaping using MQC and configuring traffic shaping using traditional FRTS commands are mutually exclusive. Traffic shaping cannot be configured on the same interface using both methods."
-amit singh
Edison Ortiz Wed, 11/14/2007 - 07:17
Hi Amit :)
1. Here is the output I get if I try to enable frame-relay traffic shaping under a serial interface with MQC configured.
Rack1R2(config-if)#frame traffic-shaping
Generic traffic shaping commands must be removed before enabling frame-relay
traffic shaping.
2. Correct, the following output from an interface configured with MQC FRTS
Rack1R2#sh policy-map interface
Serial1/0: DLCI 203 -
Service-policy output: FRTS
Class-map: class-default (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
192000/192000 240 1920 0 10 240
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 0 0 0 0 no
Rack1R2#sh run | sec MQC-FRTS
class MQC-FRTS
map-class frame-relay MQC-FRTS
service-policy output FRTS
Rack1R2#sh run | sec policy-map
policy-map FRTS
class class-default
shape peak 192000 1920 0
Rack1R2#sh run int s1/0
interface Serial1/0
ip address
encapsulation frame-relay
serial restart-delay 0
frame-relay map ip 203 broadcast
frame-relay interface-dlci 203
class MQC-FRTS
no frame-relay inverse-arp
