AAA on C870
Nov 14th, 2007
When adding aaa onto a C870 it doesn't like the following lines of code:
aaa authorization commands 1 default group tacacs+ if-authenticated local
The device appears to have a problem with the word 'local'
We use this code on all our other Cisco devices (depending on IOS versions) and they have no issues
The show version for this device is:
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4)T2, REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 22-Feb-06 21:07 by ccai
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
Can you please help us sort out why this is happening, as we cannot login correctly without the command
Paul J.
jsivulka Tue, 11/20/2007 - 10:04
Only the "line" option fails. Maybe an update to the release note would be helpful.
