VPN on UC520
ivillegas Tue, 11/20/2007 - 10:05
Check if you have firewall that is blocking the Vpn connection. Make sure following ports are opened on UDP port 500 - Which is for ISAKMP , UDP port 4500 - Which is used when the client is coming through a NAT device , ESP protocol - which is protocol 50 used for encryption. Go through the Acceslist statement carefully to allow the ip traffic on Bvi interface. Refer URL
http://cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805e8c80.shtml for configuration assistance.
