Restore CM 4.1(2) to 4.1(3)
Answered Question
Nov 14th, 2007
I need to rebuild and then restore a backup of CM 4.1.2 but I cannot find the disks. Is there any way I can use 4.1(3) disks and restore into that.
Correct Answer by rob.huffman about 9 years 2 months ago
Hi Michael,
Sorry to say, this is not a supported method :( Here is a clip from the CCM 4.1(2) Backup and Restore documentation;
Do a system restore on the same Cisco CallManager version. Changes from release to release cause problems if you try to restore from a different version.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_troubleshooting_guide_chapter09186a00802e0e9d.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Wed, 11/14/2007 - 07:43
Hi Michael,
Hope this helps!
Rob
