Privilege user mode ---- Enable
Nov 14th, 2007
When telnet to my ASA 5510,
it took the password I entered.
But when typed "enable" to enter
the privilege mode, the ASA prompted
for a user name instead of a password. Then I entered "enable_15"
with the known password, but the ASA
did not take it? Please see the log below.
Do you know why? Thanks!
User Access Verification
Password:
Type help or '?' for a list of available commands.
ciscoasa> enable
Username:
Username: enable_15
Password: ***
Username:
Overall Rating: 4 (1 ratings)
ajagadee Wed, 11/14/2007 - 08:51
  • Cisco Employee,
Based upon your description, looks like you have authentication configured for Enable Command.
Based upon the authentication method that you are using for enable command, that is Local, TACACS+ or RADIUS, you need to use the right combination of Username/Password to get access to this device.
Please refer the below URL for details.
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/mgaccess.html#wp1042030
Let me know if it helps
Arul
