Unable to remote telnet to a Cat 3548XL
paulmoore69
I'm trying to set up remote access to a Cat 3548XL using reverse telnet from a Xyplex 1604 Maxserver. I have configured the Xyplex and can access 2600 routers and also Cat 3550 switches without any problem. If I take the console from the 3550 and put it in the 3548 I do not get any response from it. The line on the Xyplex appears OK. I have tried 2 3548's and both do the same. I've tried messing with the line configuration on the Xyplex but getting nowhere.
Has any one had this problem before and resolved it...??
aghaznavi
Level 5
Level 5
The issue may be with the console configurations or the username and password used to authenticate is not in the remote router database. Check the authentication process.
