ACS 4.1 change Radius listen port
Nov 14th, 2007
In ACS 3.3 it was possible to specify the radius listen port with registry keys:
[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco\CiscoAAAv3.3\CSRadius]
"AuthenticationPort"=dword:0000064e
"AccountingPort"=dword:0000064f
"AuthenticationPortNew"=dword:0000064c
"AccountingPortNew"=dword:0000064d
This does not work anymore in version 4.1.
Does anyone know how to change the radius listen port in version 4.1 ?
Gerard van Bon
darpotter Wed, 11/14/2007 - 10:39
In 4.x all registry config was moved into the sql anywhere db.
If you can get hold the Sql Anywhere dev kit to get the Db edit app AND know your ACS database password and then can find the value in the table structure.. then yes you could change the RADIUS listen port.
