Linking 2 T1 in 1750
Nov 14th, 2007
We currently have a functioning T1, just purchased a second T1 for the 3meg capability (was told by our rep that our current equipment will work).
Question.
1. Is it possible to combine the 2 T1 in the 1750?
2. Can you help or give me some links to refrences that may help?
After some reading I gather that the router must support MLFR (yes we are runung a T1 over Frame Relay). Does this router support MLFR? The version is 12.3.
Any help with this topic will be be greatly appreciated. Thanks
kpatram Wed, 11/14/2007 - 19:42
Thanks, I already looked at that, I guess I should have been more specific.
When I try to enter the command "interface mfr mfr1" I am getting invalid command, I even tried "interface mfr1" same thing, I can however configure the subinterface. Its wired that I cannot configure the main mfr, Any Ideas.
Again Router is 1751 and Ios is 12.3
desai.jaideep Wed, 11/14/2007 - 20:00
  • Gold, 750 points or more
Pls give the config you are doing with " sh ip int br"
JD
kpatram Wed, 11/14/2007 - 20:19
Station_Router#sh ip int br
FastEthernet0/0 #.#.#.# YES NVRAM up up
Serial0/0 #.#.#.# YES NVRAM up up
Serial1/0 unassigned YES unset up down
Station_Router#
kpatram Wed, 11/14/2007 - 21:03
Station_Router#sh run
Building configuration...
Current configuration : 1275 bytes
! Last configuration change at 02:42:26 edt Mon Nov 5 2007
! NVRAM config last updated at 23:18:58 edt Sun Nov 4 2007
version 12.3
service password-encryption
hostname Station_Router
boot-start-marker
boot-end-marker
enable password qqqqqqqqqqqqq
clock timezone edt -5
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip flow-cache timeout active 1
no ftp-server write-enable
interface FastEthernet0/0
ip address #.#.#.# 255.255.255.0
no ip route-cache cef
ip route-cache flow
no ip mroute-cache
speed 100
full-duplex
interface Serial0/0
ip address #.#.#.#255.255.255.252
encapsulation frame-relay IETF
ip route-cache flow
no ip mroute-cache
no fair-queue
interface Serial1/0
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 #.#.#.#
no ip http server
snmp-server community scrubber RO
snmp-server community conpres RW
snmp-server ifindex persist
snmp-server enable traps tty
line con 0
password 7 qqqqqqqqqqq
line aux 0
password 7 qqqqqqqqqqqqqqqqq
line vty 0 4
login
end
Station_Router#
desai.jaideep Wed, 11/14/2007 - 21:41
can you try giving "encap fra mfr1"
on both the interfaces and then try "int mfr1"
JD
kpatram Thu, 11/15/2007 - 04:58
Same thing.
Station_Router(config-if)#encap fra mfr1
% Invalid input detected at '^' marker.
paolo bevilacqua Thu, 11/15/2007 - 05:19
  • Hall of Fame,
    Founding Member
It can happen that the 1750 platform was not getting the feature at the same announced time of 12.2(T).
So you should upgrade to something like latest 12.4 mainline and try again. You may also need to upgrade flash and ram at the same time.
