DHCP over 1300 Bridges
Nov 14th, 2007
I have 1300 bridges in station root and non-root mode and all the vlans can communicate across it with address assigned. But when a new unit (pc or phone) is attached.....the DHCP broadcast does not get sent across the wireless link to the DHCP server. What config change is needed to allow these broadcasts?
Overall Rating: 4.5 (2 ratings)
bbxie Wed, 11/14/2007 - 17:49
  • Silver, 250 points or more
if the DHCP server and client are on different vlan, make sure DHCP relay is enabled in the attached router/L3 switch
johnminon Thu, 11/15/2007 - 06:16
The DHCP server is on a router with a fastethernet set up as a dot1q trunk with all the vlans attached as sub-interfaces.
It is the broadcast that is not going across the wireless connection.
If i were to apply DHCP relay...where would i put it???
srosenthal Thu, 11/15/2007 - 07:13
The DHCP relay would need to be on the first layer 3 interface that the broadcast will get to.
Do you have a switch attaced to the non-root bridge or are you just directly attaching a device to the bridge?
If you are using a switch, you will need to set the switchport to use the proper VLAN that you desire.
As for the DHCP scope being on the router, you need to be certain that is in the same network as the VLAN you are connecting to. If your switchport is setup for VLAN10, and you do not have scope defined in the network space for VLAN10, then you will not get an address.
DHCP scopes will only assign an address to a device that is in the same VLAN that it is established for.
Can you post the router config?
Seth
johnminon Thu, 11/15/2007 - 07:27
Her is the pertinent info from router:
no ip dhcp use vrf connected
ip dhcp excluded-address 10.1.102.0 10.1.102.10
ip dhcp excluded-address 10.1.102.251 10.1.102.255
ip dhcp pool ipphone
network 10.1.102.0 255.255.255.128
default-router 10.1.102.1
option 150 ip 10.1.249.40 10.1.249.140
domain-name pdcarea.lcl
dns-server 10.1.1.10
interface Loopback0
ip address 10.1.255.2 255.255.255.255
interface FastEthernet0/0
description Trunk to sw1
no ip address
duplex auto
speed auto
interface FastEthernet0/0.200
description VLAN 200 Wireless Infrastructure
encapsulation dot1Q 200
ip address 10.1.200.1 255.255.255.240
no snmp trap link-status
interface FastEthernet0/0.300
description VLAN 300 Data xxxxx
encapsulation dot1Q 300
ip address 10.1.2.10 255.255.255.0
interface FastEthernet0/0.400
description VLAN 400 voice xxxx
encapsulation dot1Q 400
ip address 10.1.102.1 255.255.255.0
interface FastEthernet0/1
ip address 10.1.240.9 255.255.255.248
duplex full
speed 100
and on the switches I have all the ports set up as dot1q trunks with vlan 200 as the native to match the BVI interface.
I am passing multiple vlans across the wireless bridge such like a wired trunk port....
John M.
kka Sat, 11/17/2007 - 10:59
What IOS version are using on the bridges? There were
some bugs in older versions with DHCP not working.
I have an almost identical setup (trunk-bridging,
Cisco router as DHCP server), this works with IOS 12.3(11)JA1.
There is no DHCP-relay necessary.
One thing strange in your router config:
The netmask for your DHCP-pool "ipphone" is 255.255.255.128,
while on the interface Fa0/0.400 it is 255.255.255.0.
johnminon Mon, 11/19/2007 - 06:50
Version 12.4(3g)JA1 is the IOS I am using...am going to check the bug tool kit
The addressing issue is correct.....that is a typo.....good lookin out!!!!
johnminon Mon, 11/19/2007 - 09:03
Upgraded the IOS to 12.4(10b)JA and it works now. There is no bug on the old IOS....looked for a while.
Thanks for the help
