AAA with CatOS and ACS (shell command autorization set)
Nov 14th, 2007
I have an ACS that authenticates and authorizes IOS devices.
I use "shell command autorization set" to authorize some commands for some groups.
Is it possible to do so with CatOS?
For example, I'd like that the groupe FULL can access all command and the group LOW can onmy access "sho" commands?
ROMS
Jagdeep Gambhir Wed, 11/14/2007 - 14:32
  • Red, 2250 points or more
Roms,
Concept remains the same for IOS and CAT OS. You need to define command author set for cat os.
~JG
rdubo Thu, 11/15/2007 - 04:20
Ok, and what should be the configuraio of the switches. I see there is few available command for CatOS...
somishra Thu, 11/15/2007 - 04:58
  • Cisco Employee,
The following command is reqd to enable command authorization on set-based switch:
set authorization commands enable [config | all] tacacs+ [deny | none] [console | telnet | both]
tnx
somishra
Jagdeep Gambhir Thu, 11/15/2007 - 06:02
Console> (enable) set tacacs server [IP] [primary]
set tacacs key [key]
set tacacs attempts [number] (optional)
set localuser user [user] password [password] privilege 15
set authentication login local enable
set authentication login tacacs enable [all | console | http | telnet] [primary]
set authorization exec enable tacacs+ [deny | none] [console | telnet | both]
set authorization commands enable [config | all] tacacs+ [deny | none] [console |telnet | both]
regards,
~JG
Jagdeep Gambhir Thu, 11/15/2007 - 06:10
Here is the sample screen shot. Also note that CAT OS do not support local AAA fallback until version 7.5 when the 'set localuser' command was introduced.
~JG
Do rate helpful posts
