Nov 14th, 2007
I need to create an always-on VPN connection between two offices. The main office has a UC500. Is an ASA box the right choice for the remote office, or do I need to go with an ISR?
Overall Rating: 5 (1 ratings)
Collin Clark Thu, 11/15/2007 - 07:29
Depends, do you have any other requirements of the device? Things like firewalling, routing, services like Netflow or URL filtering?
kplunkett512 Wed, 02/20/2008 - 05:22
I highly recommend the ISR. We use 871's for this type of deployment and they work great. If you're hanging phones off of remote site, I've attached a guide provided by TAC for 871 configuration of the IPSec VPN tunnel. You can pick out the pieces that apply for your configuration.
velocitystorm Sat, 03/01/2008 - 17:18
Can you repost the guide? I was reading through various posts and found this. I have to do this soon for a customer so it would be a good one to have.
