MPLS LAB Setup
Nov 14th, 2007
Hai All,
I wud want to set up a MPLS backbone Lab...for this what is the minimum requirement ...how meny routers &...IOS Version ....
Please help me regarding this .. can 1700 series support MPLS if so what is the recomended IOS .. i should use ..
Thanks in Advance..
Lijesh.N.C
guruprasadr Wed, 11/14/2007 - 21:41
  • Gold, 750 points or more
HI Lijesh, [Pls Rate if HELPS]
CPE ==> 4 Routers
MPLS Cloud:
PE ==> 3 Routers
CPE1 via E-BGP to PE1
CPE2 via E-BGP to PE1
CPE3 via E-BGP to PE2
CPE4 via E-BGP to PE2
Inside MPLS Cloud:
PE1 via MP-IBGP to PE2 (vice-versa)
PE1 to P1 (OSPF Sync)
PE2 to P1 (OSPF Sync)
Neverthless, investing in Physical Routers => You can use Dynamips the Virtual Router Setup.
With this you simulate with CISCO 7206 Router with latest IOS Release.
Do Rate if HELPS
Best Regards,
Guru Prasad R
CSCO10758684 Wed, 11/14/2007 - 22:07
hai Prasad,
Let me try the same i will let you know the status
Thanks for the fast reply
