UT on LMS 2.5 Campus Manager 4.0.5
Nov 14th, 2007
On catalyst 6500 series cannot acquire the end host information like the IP address, MAc and host name. The switch is not discovering the UT, even it was already appearing the device green on my Network Topology, Credentials already set, Cisco View is running fine.Inventory and Archive Mangement is collecting it properly.All of other switches are showing the End Host information. Guys need your assistance on this matter.
Joe Clarke Thu, 11/15/2007 - 08:35
Campus Manager 4.0.5 is fraught with bugs that could explain what you're seeing. I highly suggest you upgrade to LMS 2.6, then up to CM 4.0.9. After doing this, you will need to reinitialize your ANI database.
However, if you want to do some more troubleshooting on this, you will need to enable core, corex, framework, frontend, and vmpsadmin debugging under Campus Manager > Admin > Campus Data Collection > Debugging Options, then run a new Campus Data Collection followed by a UT major acquisition, then post the ani.log and ut.log.
