Router booting in Rommom mode no Image---Urgent
Nov 14th, 2007
I was upgrading image of router 3725 and old image between(accedentely) the router reloaded and now booting in rommon mode as there is no image in flash...please suggest how to uload new image...Thanks in advance
Overall Rating: 5 (1 ratings)
saimbt Wed, 11/14/2007 - 23:44
Please set the baud rate to 115200, otherwise the transfer will take ages to complete.
Paolo Bevilacqua Thu, 11/15/2007 - 03:59
Excuse me, why is that one has have to use xmodem when LAN interface are avaialable ?
At rommon prompt, type "tftpdnld". It will list the variables that need to be set. Set themform rommon promtp, connect tftp server to router lowest lan interface and repeat tftpdnld.
rajatsetia Thu, 11/15/2007 - 07:14
bevilacqua has nailed it. it will take ages with xmodem (i have used it when i was not aware abt the rommon procedure).. :)
attached is the doc for this process ( for 2600 router, will be same for 3700 also)
chk the "Copying an Image from a TFTP Server Using the tftpdnld Command " section.
ghanshyam.saini Thu, 11/15/2007 - 04:22
As you know I have router 3725 and the reason why i was upgrading the image was when I try to configure BGP router ASN it gives Protocol not in this Image and even after image upgrade ( now c3725-ipbase-mz.123-9e) it shows the same please help
Paolo Bevilacqua Thu, 11/15/2007 - 04:35
You may need "sp" or "advanced ip services" image for BGP, not "ip base".
