carl_townshend Fri, 11/16/2007 - 08:36
but this is more like a broadcast right? where all pc's see the broadcast but only 1 will listen to it, is this the same for multicast but multiple pc's listen to it but the frame still gets flooded to all ports unless setup correctly via snooping ?
yagnesh_tel Fri, 11/16/2007 - 09:02
  • Silver, 250 points or more
Yes you are correct when you say that it is broadcast as Ethernet switch has no way to determine what ports the group members are on. As a result, the multicast traffic is forwarded to all ports except source port. So this is sort of business as usual for switch untill you configure it with IGMP snooping or CGMP in order to make it identify source and group member ports.
