DTMF tones on SIP Trunk
Adam Frankel Fri, 11/16/2007 - 04:15
Would need detailed CCM Traces to determine the exact cause, but you may be hitting CSCsh40465, which is fixed in 5.1(3).
Adam Frankel Fri, 11/16/2007 - 04:16
And by detailed CCM traces I mean - detailed CCM traces of a phone registering on the CCM side, and a call out the SIP Trunk.
wilsonhew Thu, 10/16/2008 - 03:52
Hello, I am facing the same issue with Nortel interop:
Nortel CS1000M --> (IP) Cisco VG --> Call Manager 6
Calls got established but DTMF not transmitted. Do I need to upgrade the VG to CUBE IOS?
Any other options available to solve the interop issue?
Appreciate your feedback.
Wil
