can I divide my Bandwidth dedicated for VoIP
Nov 15th, 2007
Hi All,
Please advice me what I wanted to do is possible or not.
I have 128 kbps Bandwidth leased line circuit to my branch office in Singapore and I would like to dedicated assign 64 kbps of my bandwidth for VoIP traffice. The rest traffic with go with another 64 kbps.
I am using cisco 1760 routers and is it possible to do?
Any advice will be appreciated.
Overall Rating: 4.3 (3 ratings)
paolo bevilacqua Thu, 11/15/2007 - 05:57
  • Hall of Fame,
    Founding Member
Yes, use LLQ QoS for this.
class-map voice
match dscp ef
policy-map llq
class voice
priority 64
class class-default
fair-queue
interface serial x/y
service-policy output llq
after that, observe results with "show policy-map interface". If no packets matches class voice, your voice traffic is not marked dscp ef, as it should be so. either fix traffic or reconfig class voice.
mintheinkyaw Fri, 11/16/2007 - 03:05
Hello Sir,
Thanks for your advice.
But I could not understand what is..
class class-default <-- and I also can not type this command in router.
please advice me if you have time.
paolo bevilacqua Fri, 11/16/2007 - 04:17
  • Hall of Fame,
    Founding Member
That would all traffic not matching class voice, ive fair queueing. It is not really necessary to have that, but is beneficial expecially on slow links.
Which exact IOS are you using ?
mintheinkyaw Fri, 11/16/2007 - 18:07
IOS version is "C1700-IPVOICE-M (Version 12.3(7)XR3.
paolo bevilacqua Sat, 11/17/2007 - 02:29
  • Hall of Fame,
    Founding Member
If you cannot upgrade IOS, just leave it without "class-default". Wath matters, is priority for voice.
As a recognition to those providing answers, please rate useful posts with the scrollbox below!
mintheinkyaw Sun, 11/18/2007 - 17:50
I have two routers connected. So, do I need to configure for both sides?
Thanks.
mintheinkyaw Mon, 11/19/2007 - 19:45
Bevilacqua,
I just configure on two Routers. Once I finised the configuration. I saw below output with not packets transfering.
Router#sh policy-map interface
Serial0/1
Service-policy output: llq
Class-map: voice (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: dscp ef
Queueing
Strict Priority
Output Queue: Conversation 40
Bandwidth 32 (kbps) Burst 800 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
3269 packets, 2187341 bytes
5 minute offered rate 57000 bps, drop rate 0 bps
Match: any
Router#
After I made some ph calls. I can see below output showing packets transfering.
Serial0/1
5045 packets, 322159 bytes
5 minute offered rate 5000 bps, drop rate 0 bps
Match: dscp ef
Queueing
Strict Priority
(pkts matched/bytes matched) 3115/128688
16895 packets, 10045657 bytes
5 minute offered rate 81000 bps, drop rate 0 bps
Match: any
Router#
So, is it working fine now? How can I check it is actually reserver the bandwidth for voice?
Thanks for your kind help.
paolo bevilacqua Tue, 11/20/2007 - 09:55
  • Hall of Fame,
    Founding Member
yes, it seems you are using a low bitrate codec, w/ vad.
You have reserved 32 kbps for voice. When there is no voice traffic, data can use that bandwidth.
As a recognition to those providing answers, please rate post if it helps!
