7936 Conference Station boot issues
ckltd7401 Thu, 09/18/2008 - 08:12
To manually reset the 7936 to factory defaults, you need to enter the Admin Setup menu on the physical phone and select "Restore Defaults". You may be prompted for the passcode before gaining access to the Admin Setup menu; default passcode is **# key sequence on the phone. I've got a 7936 doing the same thing. I have already reset to factory defaults and can ping all UCCM servers in the cluster; still getting "Cannot contact TFTP server". I'm actively searching the forums for answers; found your post from almost a year ago. I hope this helps you, but it didn't help me. :-(
ck
Justin Brenton Thu, 09/18/2008 - 16:44
  • Silver, 250 points or more
Hi Sydneyd,
Do you have a ip address listed in the TFTP field on the phone?
Justin
