CM OS install error #1838
Nov 15th, 2007
Im trying to install the OS onto a HP DL380 G3. I have checked all hardware compatibility and everything checks out ok.
I have tried different OS disks and versions including 2000.2.4 2000.2.6 and 2000.2.7
The hardware detection cd works fine and it then asks me for disk 2. Disk 2 runs for a minute and then gives and error #1838 invalid drive number.
Anyone seen this?
Michael
hadbou Wed, 11/21/2007 - 11:57
  • Bronze, 100 points or more
Bug -CSCdy66516.
Workaround:
Reboot the system with OS CD and run again, plus the second CD.
If the error is not seen after the second attempt and:
1) if the RAID configuration is correct (2 RAID 1 logical drives)
2) if the F: drive exists and has a VOLUME label of "Trace" then the configuration is valid and correct.
mlong0000 Thu, 11/22/2007 - 01:45
turns out what was wrong was I HAD to have 4 hdds in the server
