Cisco 6500 Ports Usage Utility
Answered Question
Nov 15th, 2007
Dear All,
I have a Cisco 6500 catOs Version 8.2(2), the rack where 6500 is placed is a disaster a lot of rj45 cables it seems like a jungle.
The 6500 has the following modules:
N2 WS-X6K-SUP2-2GE with WS-F6K-MSFC2
N1 WS-X6224-100FX-MT
N4 WS-X6248-RJ-45
N2 WS-X6248-TEL
I'd like to know which ports are in use in the modules WS-X6248-RJ-45, WS-X6248-TEL,there is some port usage statistics?
Thanks in advance, best regards.
Igor.
Correct Answer by andrew.burns about 9 years 8 months ago
You can use the "show mac" command to get total packets received/transmitted and "show mac utilization" to get the last 5 minute traffic rate.
Andrew.
Overall Rating: 4 (3 ratings)
Collin Clark Thu, 11/15/2007 - 07:31
  • Purple, 4500 points or more
You could use SNMP to view the last time the port status changed. The OID is .1.3.6.1.4.1.3076.2.1.2.17.1.1.0
Tools such as Solarwinds Engineer Toolset make this much easier.
HTH and please rate.
ifabrizio Thu, 11/15/2007 - 07:41
Many thanks for your reply, the SNMP is a good way to approch the problem but require an additional software.
I 'd like to know if there is some utility in the CatOs to do this job.
Best regards,
Igor.
Collin Clark Thu, 11/15/2007 - 07:47
Not that I know. There are free SNMP Managers out there too.
Correct Answer
andrew.burns Thu, 11/15/2007 - 09:36
  • Gold, 750 points or more
Andrew.
