CATOS Tacacs and authentication
Nov 15th, 2007
All- I am implementing TACACS across the network.
all the IOS's, Pix's and VPN solutions are complete.
The problem is the CAT OS switches,
i am testing with a CATOS 2948G switch.
see the config below.
Cisco Systems, Inc. Console
OMKSW02 (Cisco Catalyst 2948G)
Access Restricted...
Username: catsoup
OLTEST2948G en
Enter password:********
OLTEST2948G (enable) sh run
This command shows non-default configurations only.
Use 'show config all' to show both default and non-default configurations.
set tacacs server primary
set tacacs attempts 6
set tacacs directedrequest enable
set tacacs key hello
set authentication login tacacs enable console primary
set authentication login tacacs enable telnet primary
set authentication login tacacs enable http primary
set authentication login attempt 6 console
WHAT is needed toget rid of the enable password prompt..
I can disable the enablepassword but would prefer not to.
strykerb41 Thu, 11/15/2007 - 07:47
actually found the info....
Posted by: jgambhir - Nov 15, 2007, 6:02am PST
Console> (enable) set tacacs server [IP] [primary]
set tacacs key [key]
set tacacs attempts [number] (optional)
set localuser user [user] password [password] privilege 15
set authentication login local enable
set authentication login tacacs enable [all | console | http | telnet] [primary]
set authorization exec enable tacacs+ [deny | none] [console | telnet | both]
set authorization commands enable [config | all] tacacs+ [deny | none] [console |telnet | both]
glen.grant Thu, 11/15/2007 - 08:59
if you want it to use the tacacs password for enable add
set authentication enable tacacs enable telnet primary
