Can CallManager use in his DIAL Plan a remote CME's gateway in order to use her PSTN connection to pass through it the call that have the PSTN as target and is there any docs related to this topic.
You should create a SIP trunk in CCM to route the calls to the CME gateway.
Also you should create a dialpeer in CME to route incoming calls to the CCM.
Alex
