Changing the .bin file on a 2811 Router
Answered Question
Nov 15th, 2007
In order to change the .bin file on my 2811 router can I just delete c2800nm-advsecurityk9-mz.1243h.bin and replace it with c2800nm-advanterprisek9-mz.124-6.T8.bin?
Is that allI have to do to reload it?
This is the first one I have had to reload the IOS on.
Correct Answer by Collin Clark about 9 years 6 months ago
Yes, you can delete it with:
erase flash:/c2800nm-advsecurityk9-mz.1243h.bin
You could also keep it there in case there is a problem with new image. You would copy the file to flash and then go into config mode and type:
boot system flash:c2800nm-advanterprisek9-mz.124-6.T8.bin
This will tell the router what image to boot (otherwise it will boot the first image in flash).
HTH and please rate.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Thu, 11/15/2007 - 08:25
  • Purple, 4500 points or more
