Installation CCM 6.0.1 with DMA
Nov 15th, 2007
is it possible to backup a DMA-Database from a CCM 4.2.3 running on MCS-7835I-3.0-IPC1 and use this Backup tar-file for a fresh installation of 6.0.1 on another platform, for example MCS-7825-H3-IPC1 or can I upgrade only on the same
model.
kind regards
Mathias
loevans Thu, 11/15/2007 - 10:45
I am not 100% sure about the 6.x dma, but can tell you for sure from 5.1.3 dma, you can install on ANYTHING you want. I have done it on multiple server types as well as on a VM image in a lab for testing.
LE
