Menu Timeout - Are You Still There?
Answered Question
Nov 15th, 2007
My script works per our requirement. Only problem is when I use the Menu step, after the Timeout value (10 secs from the time the last spoken word in Menu Prompt), the system says "Are you still there?". Do you know how I can remove this? Please advise, thanks.
Correct Answer by clarkjason about 9 years 5 months ago
Change maximum retries to 0 and set timeout back to label before the menu statement, if you still need a timeout use an increment on a counter variable to accomplish this?
Overall Rating: 4 (1 ratings)
Correct Answer
clarkjason Thu, 11/15/2007 - 10:54
junp14 Thu, 11/15/2007 - 11:15
Thanks, changing the Max Retries to 0 fixed it, I didn't have to change the Timeout. Thanks again.
