Extension Problem
Answered Question
I have a couple of extensions that can not be dialed from the company menu. When I dial into the menu and the system prompts for the extension, I enter the extension and it just pauses and rings back into the main menu. Any ideas to point me in a direct to look at?
Correct Answer by t.radan about 9 years 3 months ago
Danny is correct, you will have to set them up with a voicemail box in order to have them available in the directory/auto attendant.
I know it is not what you want, but that is the fix.
Teresa
Overall Rating: 4.5 (2 ratings)
Not sure to be exact. system was setup by Bell Canada.
I didn't think an extension needed a voicemail box to be able to dail it from a company menu.
If I call our 800 number and out automated menu system is activated, it asked for the extension you want to call. If I enter the extension, it will not ring that phone, but just goes back into the company greeting and menu?
What I am trying to do is:
we have sales people on the road. I have 4 digit extension setup that forward to their cell phones. Those internal directories work if you dial them directly from your phone. If I was to call our 800# and enter an extension of a sales person, it will not ring to that number, but just loop back to the menu system.
Hopefully that is a clearer picture.
Correct Answer
t.radan Fri, 11/16/2007 - 11:31
Teresa
Rob Huffman Fri, 11/16/2007 - 18:06
Hi RG,
Just to add a note to this good info so far :) You could set these Extensions in Unity up as Internet Subscribers, which does not require a User License but does allow them to be listed in the directory and to be able to be dialed from the Call Handler.
Creating Internet Subscriber Accounts
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_feature_guide_chapter09186a0080449a88.html#wp1039005
Hope this helps!
Rob
