NAC Rollout
Nov 15th, 2007
I am trying to rollout CTA and Symantec's SymSentry for posture validation on Remote Access Users. Does anyone have any suggestion on the best way to do this? I would like one stop shopping.
My goal is for a remote user to login via VPN and have the NAC process start. If you do not have CTA or SymSentry entries loaded, it would take an unknown posture validation that would redirect you to a website that basically says if you want access to the domain, you will need to click here. Once you click ont he link, it will install CTA and SymSentry agents and then do another posture validation to see if one will need ot update.
Does anyone have any other way that would be easier than this?
Thank you in advance.
