7604 interface can't do fair queueing - is there a workaround?
Nov 15th, 2007
I'm transferring a gig connection from a 7206 router to a 7604 router (IOS = 12.2(33)SRB2) to get more throughput. The configuration has standard LLQ QOS classes for voice and video and class-default.
When I copy over the classes and policy-maps from the 7206 to the 7604 and apply them to a SPA-2GE interface, the IOS complains that the interface cannot do fair-queueing. Here are the class maps and policy map from the 7206:
class-map match-any Call-Control
match ip dscp cs3
class-map match-any Video
match ip dscp af41
class-map match-any Voice
match ip dscp ef
policy-map QOS_classes_48calls_1video
class Voice
priority 4560
class Video
bandwidth 480
class Call-Control
bandwidth 100
class class-default
fair-queue <----- I had to remove this
random-detect
I like how fair-queueing worked in class-default on the 7206 and would like the same on the 7604, but it seems like it can't do that.
Is there another way to do this, or is this something that is a limitation of the hardware, or will future IOS releases incorporate the feature?
owillins Wed, 11/21/2007 - 13:43
  • Silver, 250 points or more
Remove and then reconfigure fair-queueing in SPA-2GE interface so that it will set the correct value after that try it will work.
ratheeshrg Wed, 11/21/2007 - 20:31
From the configuration it is understood that you are CBWFQ + PQ ( which in effect become LLQ). Your default class will invite a queue in the QoS process and you dont have to mention any queing for the same.
randome-detect command will invite WRED and conj management will be done.
