Restore with BARS
Nov 15th, 2007
Wonder if any of you have done a restore yet? I made a booboo today and deleted 46 extensions. I backup every night so tonight I was going to do a restore.
1. do I have to do a restore from the server or can I be remote?
2. any way to undo a delete booboo and not have to restore.
this is a 4.1(3) ccm
UCBNOCWAN Wed, 11/21/2007 - 01:41
I hope that you are regularly using BARS to backup your CCM configuration / data. You can take the last backup file taken when the 46 phones were registered. ( If you remember the date)
There is no way you can undo a delete operation.
HoustonG33K Sat, 11/24/2007 - 15:12
I do back-up every night. I did the restore and it took 1 hour. It put all phones back but when called they would go straight to VM. I had to do a restart on all the effected phones (the ones I deleted). Thanks for the help.
