CCM 5.1.3 admin/serviecibility session timeout values
Nov 15th, 2007
CCM 5.1.3
Is there any way to change the session timeout values when accessing the CCM web pages?
I need to increase this value for our telecomm analysts accesing the administration or serviecibility web pages.
Thanks.
Overall Rating: 4 (2 ratings)
roboliveira Tue, 06/03/2008 - 11:16
I am running into this same issue with 6.1. Did you ever find the answer?
roboliveira Tue, 06/03/2008 - 12:02
Ok thanks! Hopefully someone else has run into this and can give us an answer.
Jaime Valencia Mon, 07/06/2009 - 18:05
There is already an enhancement for this, right now there is no way to change the 30 minute timeout in any CUCM version
java
if this helps, please rate
Clifford McGlamry Mon, 08/03/2009 - 06:39
Is there any timeframe on the roadmap to deliver the enhancement or information about what versions it will apply to?
Jaime Valencia Mon, 08/03/2009 - 06:48
No, i'd recommend you to look regularly at the enhancement for news or do as instructed in the bug
CSCsj45520
configurable CCMAdmin timeout
Symptom:
Browser session to CCMAdmin times out after 30 minutes and user must re-authenticate.
Conditions:
Browser session to CCMAdmin idle for 30 minutes with CM6.x.
Workaround:
None. Reauthenticate after 30 minutes of inactivity.
Further Problem Description:
This is an enhancement request to allow configuration of web session timeout. Please contact Cisco account team or Cisco Product Manager for status, details, and updates about this enhancement request.
java
