Rob Huffman Fri, 11/16/2007 - 05:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Sunny,
Hope all is well with you :) Now, I hope that I am understanding your question here correctly. If you are trying to configure CUE to integrate with CME, there will be certain configs required on both sides, here are some really good "getting started" configuration type docs;
Cisco CallManager Express/Cisco Unity Express Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
Cisco CallManager Express 3.0 and Later Integration with Cisco Unity Express
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a008059fb5f.html
Cisco Unified CallManager Express Solution Reference Network Design Guide
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_implementation_design_guide_book09186a00805f05db.html
Hope this helps! Have a look at these for your initial ideas :)
Rob
sunnyverghese Fri, 11/16/2007 - 12:48
Hi Rob
thanks a lot for your help . i have gone through the links it is really helpful .do you have msn id or yahooid i would like to send the config files
