7911 time zone CME
Nov 15th, 2007
hi, we've a C2851 with CME 4.2 IOS Ver advipservicesk9-mz.124-11.XW3, & have problems with time zone, only in IPphone 7911 & IPCom. The ntp & clock time zone are correctly configured & also we tried with different ios & firmwares HELP US PLS
Paolo Bevilacqua Fri, 11/16/2007 - 04:56
  • Hall of Fame,
    Founding Member
which FW on the phones ? Have you tried XW4 ?
Have you set timezone under telephony service?
vortiz_mnet Fri, 11/16/2007 - 06:04
Hi, In Mex only exist XW3 Ios Ver to C2851, we tried with: xw1, xw2 & xw3. On the phones with fW Ver 7.x CP11.7-2-1-0S.loads & Ver 8.x SCCP11.8-2-2SR2S.loads. Ther router has clock time zone right & the CME also has time zone telephony service right.
clock timezone MX -6
clock summer-time MX recurring
clock calendar-valid
vmilanov Fri, 11/16/2007 - 10:35
Phones synchronise with CME to the UTC time.
CME also has a separate setting for the time-zone, so the phones can adjust their clock after synchronisation to the desired local time.
For the SCCP phones use following config setting:
Router(config)# telephony-service
Router(config-telephony)# time-zone 9
And for SIP phones use:
Router(config)# voice register global
Router(config-register-global)# timezone 9
"9" is the time-zone setting for Mexico.
More info n the UCME Command Reference: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_t1ht.html#wp1071122
Vasil
