Bonded T1s with MFR :(
Answered Question
Nov 15th, 2007
A friend of mine asked me correct his config and I have no clue. Here it is. The two serial are the existing bonded t1s. The telco added in 2 more bonded Ts that are supposed to just join into the working MFR1. I can't figure out how to configure the VWIC cards to run data and join MFR1. Thanks in advance.
controller T1 0/2/0
Framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/2/1
framing esf
linecode b8zs
interface MFR1
description EMBARQ Multilink Frame Relay
ip address 4.2.2.2 255.255.255.252
encapsulation frame-relay IETF
frame-relay multilink bid EMBARQ
frame-relay interface-dlci 57
frame-relay lmi-type ansi
interface FastEthernet0/0
no ip address
duplex full
speed 10
no mop enabled
interface FastEthernet0/0.99
description Connection to Wireless with VLAN 99 TAG
encapsulation dot1Q 99
ip address 5.5.5.5 255.255.255.248
interface FastEthernet0/1
ip address 192.168.1.1 255.255.255.224
shutdown
duplex auto
speed auto
interface Serial0/0/0
description Connection 1 to EMBARQ MFR
no ip address
encapsulation frame-relay MFR1
no ip route-cache
service-module t1 timeslots 1-24
no arp frame-relay
interface Serial0/1/0
description Connection 2 to EMBARQ MFR
no ip address
no ip route-cache
no arp frame-relay
interface Serial0/2/0:0
no ip address
no arp frame-relay
interface Serial0/2/1:0
no ip address
no arp frame-relay
Correct Answer by desai.jaideep about 9 years 6 months ago
Try this.....
int S0/2/0:0
encap fr mfr1
int S0/2/1:0
encap fr mfr1
This should work.
JD
Overall Rating: 5 (1 ratings)
ashok_boin Thu, 11/15/2007 - 20:05
  • Bronze, 100 points or more
Your question is not clear. I think you have pasted the proper working configuration.
Can you please elaborate your issue to try to resolve?
Regards...
-Ashok.
Correct Answer
desai.jaideep Thu, 11/15/2007 - 22:59
  • Gold, 750 points or more
Try this.....
int S0/2/0:0
encap fr mfr1
int S0/2/1:0
encap fr mfr1
This should work.
JD
