VPN and Microsoft Remote Desktop
Nov 15th, 2007
In the office there are users that have two monitors connected to one PC and they have different Windows displayed on each monitor. I have a VPN user that wants to be able to do the same remotely when using Remote Desktop over a VPN connection. Does anyone have any experience with this?????
jsivulka Wed, 11/21/2007 - 15:07
  • Bronze, 100 points or more
If you are not able to do it please double check, and disable the stateful firewall on your XP workstation. If you are able to ping it, this means that the application itselft is misconfigured, since with the ping you are able to use the until layer 4, and applications are on layer 7, also be sure that you have enabled the remote desktop at the "server.
http://www.cisco.com/en/US/docs/security/csd/csd311/csd_for_vpn3k_cat6k/configuration/guide/CSDwince.html
