WCS Location addition problems
Nov 15th, 2007
I've recently upgraded to the last versions WCS 4.2.62.0 and Location 3.1.35.0. According to the compatibility matrix, the versions are compatible.
When I try to add the location on the WCS, I'm having the following error: "No response from Location Server. It may be unreachable, or connectitity credentials are incorrect"
I tested the connectivity and the services, and are ok. I'm using the default config:
server-name: loc-server
ip add: 10.0.0.100
user: admin
pass:admin
port:8001
https: disable
Does anyone know what could be happening?
Thanks in advance
ericgarnel Fri, 11/16/2007 - 06:04
  • Gold, 750 points or more
Have you tried restarting or rebooting the LOC server since the upgrade?
jaimepedraza Fri, 11/16/2007 - 18:13
several times. Today I found, the admin user was not created, I manually created it, but it didn't work, I assume this user has to have some permissions.
Is there any way to restart de location to the default config?
Thx
