md110 cisco 3845 no ring back tone
Nov 15th, 2007
md110--(pri)--router3845a------router3845b--(fxo)--another pbx
md110 user call pbx user can hear ring back tone ,and everything is ok.
but when pbx user call md110 can not hear ringback tone!
3845 ios is c3845-spservicesk9-mz.124-12b
3845a:
dial-peer voice 111 voip
description for Test
destination-pattern 108....
session target ipv4:172.16.1.251
dial-peer voice 100 pots
destination-pattern 900....
direct-inward-dial
port 0/1/0:15
3845b:
dial-peer voice 1 voip
session target ipv4:172.16.2.25
port 0/1/0
anyone can help me?
xiayunduan Sun, 11/18/2007 - 21:38
voice call send_alert
voice rtp send_recv
is added,
progress_id command is added too,
debug isdn q931 is ON.
*Nov 16 01:53:02.840: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x00B2
Cause i = 0x8290 - Normal call clearing
*Nov 16 01:53:02.892: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x80B2
Cause i = 0x8090 - Normal call clearing
*Nov 16 01:53:02.892: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00B2
*Nov 16 01:53:56.740: ISDN Se0/1/1:15 Q931: RX <- SETUP pd = 8 callref = 0x00DD
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18385
Preferred, Channel 5
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '2331'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '1'
User-User i = 0x00FE, 'U', 0x0100, 'Y', 0x0100, '1', 0x0100B10C060981, '2331'
*Nov 16 01:53:56.740: ISDN Se0/1/1:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0x80DD
Channel ID i = 0xA98385
Exclusive, Channel 5
*Nov 16 01:53:56.888: ISDN Se0/1/1:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00DD
Called Party Number i = 0x81, '0'
*Nov 16 01:53:57.056: ISDN Se0/1/1:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00DD
Called Party Number i = 0x81, '8'
*Nov 16 01:53:57.224: ISDN Se0/1/1:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00DD
Called Party Number i = 0x81, '2'
*Nov 16 01:53:57.400: ISDN Se0/1/1:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00DD
Called Party Number i = 0x81, '9'
*Nov 16 01:53:57.564: ISDN Se0/1/1:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00DD
*Nov 16 01:53:57.732: ISDN Se0/1/1:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00DD
Called Party Number i = 0x81, '3'
*Nov 16 01:53:57.744: ISDN Se0/1/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x80DD
*Nov 16 01:54:00.156: ISDN Se0/1/1:15 Q931: TX -> ALERTING pd = 8 callref = 0x80DD
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Nov 16 01:54:00.160: %ISDN-6-CONNECT: Interface Serial0/1/1:4 is now connected to 2331 N/A
*Nov 16 01:54:00.160: ISDN Se0/1/1:15 Q931: TX -> CONNECT pd = 8 callref = 0x80DD
Progress Ind i = 0x8182 - Destination address is non-ISDN
*Nov 16 01:54:00.248: ISDN Se0/1/1:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00DD
*Nov 16 01:54:05.988: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/1:4, changed state to up
*Nov 16 01:54:06.160: %ISDN-6-CONNECT: Interface Serial0/1/1:4 is now connected to 2331 N/A
*Nov 16 01:54:12.120: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x00DD
User-User i = 0x00FEB1110180
*Nov 16 01:54:12.120: %ISDN-6-CONNECT: Interface Serial0/1/1:4 is now connected to 2331 N/A
*Nov 16 01:54:12.120: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8 callref = 0x80DD
*Nov 16 01:54:12.156: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x00DD
*Nov 16 01:54:12.156: %ISDN-6-CONNECT: Interface Serial0/1/1:4 is now connected to 2331 N/A
*Nov 16 01:54:12.156: %ISDN-6-DISCONNECT: Interface Serial0/1/1:4 disconnected from 2331 , call lasted 11 seconds
*Nov 16 01:54:18.156: %ISDN-6-CONNECT: Interface Serial0/1/1:4 is now connected to N/A N/A
xiayunduan Sun, 11/18/2007 - 21:40
*Nov 16 02:05:48.080: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 2903
*Nov 16 02:05:48.080: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00B3
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Called Party Number i = 0x80, '2903'
Plan:Unknown, Type:Unknown
*Nov 16 02:05:48.144: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80B3
*Nov 16 02:05:48.376: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x80B3
Progress Ind i = 0x8082 - Destination address is non-ISDN
*Nov 16 02:07:48.080: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x00B3
*Nov 16 02:07:48.128: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x80B3
*Nov 16 02:07:48.128: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00B3
*Nov 16 02:05:29.496: %SYS-5-CONFIG_I: Configured from console by vty0 (172.17.1.239)
