6509 how do you shutdown a module prior to removing it?
Nov 16th, 2007
In order to remove a module I am not using in a 6509.
i attempted to run this command from global config mode. I think i might need to log into the IDSM-2 CLI ?
For Cisco IOS software:
hw-module module module_number shutdown
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 11/16/2007 - 02:11
You should be able to shutdown the IDSM-2 module from the command line. I have used the command you tried many times on IDSM-2 and FWSM and it always worked but you don't run it from global config mode just from enable mode.
How are you verifying it has not worked. I run a "sh module" after issuing the command and the status should say "shutdown".
Jon
evan2five Sun, 11/18/2007 - 14:22
the command does not go in, comes back with unknown command and with the '^' pointer. I was attempting to run this in global config mode, not enable. Perhaps that was the issue?
Jon Marshall Sun, 11/18/2007 - 23:39
If you are running IOS then yes, that will be your problem. You can only run this command from enable mode. After running it you can run a "sh module" and look at the status of the relevant module.
Jon
Pavel Bykov Sun, 11/18/2007 - 23:56
or you can run this command with "do" prefix. Like: "do hw-module module module_number shutdown". "Do" executes ENABLE mode commands from CONFIG mode
Wilson Samuel Mon, 11/19/2007 - 05:48
If you have physicall access to the switch, you may choose the shutdown "button" on the module to bring the module down.
Kind Regards,
Wilson Samuel
Paul Murray Thu, 04/30/2015 - 01:46
To powerdown module 8, in conf t mode type:
no power enable module 8
You'll need get a status as below of PwrDown:
  8  Distributed Forwarding Card WS-F6700-DFC3C     SAL14491WAE  1.4    PwrDown
