ISDN30 <=> Network
Nov 16th, 2007
  • Gold, 750 points or more
Dear all
I am looking at 1st deployment of PABX<>ISDN30<>network.
I have a choice to hookup ISDN30 to 7609 or 4510.
does any E1 module support this interconnection or are there more rquirements I need to be take into consideration?
TIA
Sam
cisco_lad2004 Fri, 11/16/2007 - 01:09
can "NM-1CE1T1-PRI" or "NM-HDV-2E1-60" module do what is expected?
design wise, will be it be better to:
1- use a 2800 or similar + above module, and route to core network over ethernet.
2-use a Media GTW
TIA
Sam
paolo bevilacqua Fri, 11/16/2007 - 04:48
  • Hall of Fame,
    Founding Member
I think telephony cards for switches are not manufactured anymore. So you can use as small as a 2801 for this.
