CTA 802.1x wired Problems with Usernames
Nov 16th, 2007
i have a big Problem with the Connection from User over the CTA802.1x wired Client with single sign on against the Microsoft AD. (802.1x Client Version 4.0.5.5189)
When a User have the Word "from" at the beginning of his Login-name, so the Login over the 802.1x-Client failed. Nothing will be transferred from the Login-Information to the AD; i can see (or not seen)this in the Debug Mode of the involved Switch.
Is this Problem known?
Also "ä,ü,ö" will not work.
Hartmut
chenyokechuan Tue, 11/20/2007 - 18:37
Hi Hartmut,
Suggest using CSSC with CTA.
CTA 802.1x supplicant have limitation.
CSSC is free for basic features, advanced features (support wireless) need license.
You may need to un-install CTA with 802.1x supplicant first, follow by install CSSC + CTA (without 802.1x) because CSSC have built-in 802.1x features.
Please take note of the installation sequence. Because if you make mistake about the installation sequence, you may get a error and the thing didn't work.
Hope this help
