Jon Marshall Fri, 11/16/2007 - 03:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Senthil
It might help if you could give a few more details as to what you want to achieve. At a basic level the following command will turn on RSTP on a 6500 IOS switch
6500(config)# spanning-tree mode rapid-pvst
And then you can manipulate port costings by going into interface config mode
6500(config-if)# spanning-tree port-priority "number in increments of 16"
But there is a lot more you can setup with STP/RSTP and it all depends on what you are trying to achieve.
Jon
senthil.gabriel Fri, 11/16/2007 - 03:18
Hi Jon,
Thanks for your reply.
Let me update regarding the above tommorrow.
Rgds
Senthil
