Warning message
IIS Hostheader
Answered Question
Nov 16th, 2007
I am having a problem with a CSS11501, everything is working fine performing simple load balancing accross a number of IIS web servers.
However, I need the http keepalive to poll a file on the each server, but the IIS configuration requires that I use a hostheader.
I have tried using redirect-string and using a name instead of an IP address but the CSS just resolves the name and puts the ip in the config.
An pointers would be gratefully received.
Many Thanks
Rich
Correct Answer by Diego Vargas about 9 years 9 months ago
Hi Rich,
My advise is to use script ap-kal-httptag, where the value of this header(tag) can be specified as the last argument.
Considering this example configuration
service test
ip address 10.10.10.1
keepalive type http
keepalive method get
keepalive uri /test.html"
active
Modified one can be
service test
ip address 10.183.121.241
keepalive type script ap-kal-httptag "10.183.121.241 /test.html www.test.com"
active
Replace string www.test.com with the content of host header your server expects to see
instead of IP address. You find it in the IIS configuration, near the place where you
configure it to listen to host names only.
Hope it helps!!
Overall Rating: 5 (1 ratings)
Correct Answer
Diego Vargas Fri, 11/16/2007 - 10:15
  • Cisco Employee,
Hi Rich,
service test
keepalive type http
active
Modified one can be
service test
active
Hope it helps!!
rich_harris Mon, 11/19/2007 - 03:21
You're a star the httptag script was perfect.
Many Thanks
Rich
karthikraman Tue, 11/29/2011 - 02:18
Hi Diego.
Great solution.I have a similar kind of suitation on the ACE ,
Can we dont something similar on the Cisco ACE20-MOD-K9, how do we write a script on the ACE ?? Any thoughs or suggestions.
Thanks in advance.
Karthik Raman
pablo.nxh Tue, 11/29/2011 - 19:29
  • Silver, 250 points or more
Hi Karthik,
This is actually "easier" on the ACE as you don't need a scripted probe:
Just do something like this:
probe http Shop
  request method head url /shop.html
  expect status 200 200
  header Host header-value "cars.com"
  interval 15
  open 1
probe http News
  request method head url /news.html
  interval 15
  open 1
Then apply the configuration either under the rservers in the SF in question.
__ __
Pablo
karthikraman Thu, 12/01/2011 - 01:57
Hi Pablo
Thanks for your response .
The solution works fine if the probe is used for one single application running on 2 load balaced server.  The issue or
scenario that I am having is a common probe for two URL's/ web application is configured on the 2 load balanced server.
Below is the config
---------------------------------------------------PROBES---------------------------------------------------
probe http Test-Prod_PROBE
   port 80
  interval 20
faildetect 4
  passdetect interval 10
  request method head url /Testpage.html
  open 1
-------------------------------------------------RSERVERS-----------------------------------------------------
rserver host testweb1
  ip address 10.x.x.101
  inservice
rserver host testweb2
  ip address 10.x.x.102
  inservice
Note: I would use this to send anyone coming in on HTTP (80) to be redirected to HTTPS (443)
rserver redirect http-to-https
  webhost-redirection https://%h%p
  inservice
---------------------------------------------------- SSL PROXY---------------------------------------------------
ssl-proxy service ROUTER_OFFLOAD
  key router.com
  cert router.PEM
ssl-proxy service SWITCH_OFFLOAD
  key switch.com
  cert switch.PEM
-------------------------------------------------------SERVERFARMS----------------------------------------------
serverfarm host Test-Router_SFARM
probe Test-Prod_PROBE
reserver testweb1 80
inservice
reserver testweb2 80
  inservice
serverfarm host Test-Switch_SFARM
reserver testweb1 8080
inservice
reserver testweb2 8080
  inservice
serverfarm redirect GENERAL_HTTP_REDIRECT_SFARM -------> Used to redirect HTTP to HTTPS
  rserver http-to-https
    inservice
On the  two server testweb1 and testweb2 - the http keepalive - /Testpage.html  is configured on a common root directory,  and not on the application.   Hence the ACE always sees the server as up and operational. But when the  application is down and the server is up the ACE is not aware of the  face the app is down and keep sending traffice to the web app or server.
Thank
Karthik Raman
