11-16-2007 04:15 AM - edited 03-15-2019 07:16 AM
I retrived this debug form sccp:
Nov 16 12:12:44.257: SCCP:send RegisterMessage
Nov 16 12:12:44.257: SCCP:send IpPortMessage
Nov 16 12:12:44.257: SCCP:send MediaResourceNotification
Nov 16 12:12:44.281: SCCP:rcvd RegisterRejectMessage
Nov 16 12:12:44.281: SCCP:rcvd register rej reason: Error: DB Config
I use the ccm6 with a 3825(with ios ver 124-15.T) as gw.
This is my config on 3825:
sccp local GigabitEthernet0/0
sccp ccm 192.168.100.200 identifier 1 version 5.0.1
sccp ip precedence 3
sccp
dspfarm profile 12 mtp
codec g711ulaw
maximum sessions hardware 4
maximum sessions software 40
associate application SCCP
exit
sccp ccm group 999
associate ccm 1 priority 1
associate profile 12 register MTP001BD4DCAC20
any idea?
11-16-2007 10:46 AM
Looks like it is rejecting your registration.
First two things to try.
1. Make sure the name in CCM matches the name you gave it in the router.
2. Make sure you configured the right type of device in the CCM.
11-19-2007 12:37 AM
ty for your replay, i change the version option to the 3825 to 4.1, now the debug error i retrived is:
sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero for CCAPI event
any suggestions?
11-17-2008 11:06 AM
My version of CallManager is 6.1(2) I'm getting the same DB config error with both 12.4.15T7 and 12.4.22T
This is with 12.4.22T
Voice_Gateway2#show run | begin sccp
sccp local FastEthernet0/0
sccp ccm 10.68.68.10 identifier 2 version 6.0
sccp ccm 10.69.69.11 identifier 1 version 6.0
sccp
sccp ccm group 1
description MTP for DTMF Relay with Sprint SIP Trunk
bind interface FastEthernet0/0
associate profile 1 register MTP0013c3e73408
registration retries 20
registration timeout 30
keepalive retries 5
connect retries 10
switchover method immediate
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 24
debug sccp
*Nov 17 13:09:59 CST: sccp_parse_control_msg: msg_ptr 4A3D86DC, msg_len 36, msg_id 157
*Nov 17 13:09:59 CST: sccp_parse_control_msg: glob_ccm->version 8
*Nov 17 13:09:59 CST: SCCP:rcvd RegisterRejectMessage
*Nov 17 13:09:59 CST: sccp_appl_service_stop_timer: Stop 4A3D8498 timer
*Nov 17 13:09:59 CST: sccp_parse_control_msg_v1: rcvd register rej, reason: Error: DB Config
*Nov 17 13:09:59 CST: sccp_initiate_ccm_connect_interval_timer: Start CCM connect interval timer for prof_id 1, appl_type 2, interval 80
*Nov 17 13:09:59 CST: sccp_appl_service_start_timer: Start timer type 0 with time_out 80000ms
11-17-2008 11:18 AM
that is commonly caused by choosing the wrong xcoder type on CCM, maybe it's IOS enhanced but you configured regular xcoder.
check that, also try to take out the version command from MTP config
java
if this helps, please rate
11-17-2008 11:27 AM
In 6.1(2) under CCM Admin > Media Resources > Media Termination Point > Add New > you get a drop down box with only 1 option "Media Termination Point Type Cisco IOS Enhanced Software Media Termination Point"
The version type is required in 12.4.22T, you can't add it without a version, you get a error;
Voice_Gateway2(config)#sccp ccm 4.4.4.4 identifier 4 version
% Incomplete command.
Voice_Gateway2(config)#sccp ccm 4.4.4.4 identifier 4 version ?
3.0 Select CCM 3.0 version or above
3.1 Select CCM 3.1 version or above
3.2 Select CCM 3.2 version or above
3.3 Select CCM 3.3 version or above
4.0 Select CCM 4.0 version or above
4.1 Select CCM 4.1 version or above
5.0.1 Select CCM 5.0.1 version or above
6.0 Select CCM 6.0 version or above
7.0+ Select CCM 7.0 version or above
11-18-2008 04:22 AM
yes, but that config is for a XCODER, not for an MTP
java
11-18-2008 04:42 AM
Jason,
I just did an upgrade from CCM 4 to CCm 6 with gateways running 12.4.15T7. I couldnt get my CFB and XCODER to register until i removed the ver staement.
In 12.4.15T7 , you should be able to configure your sccp config without the version statement.
