SNMP Monitoring requirements for Cisco 6500 switch
I need the following MIBS for CISCO 6500 series catalyst switch.
i)SSL Module in cisco 6500 switch so that it should be report on the following statistics:
a)TCP cpu utilization
b)SSL cpu utilization
c)SSL statistics---Active connections
2)ACE Module in cisco 6500 switch
a)ACE Module statistics per context--
should be able to report on the following statistics for each context:
conc-connections
mgmt-connections
proxy-connections
xlates
bandwidth
connection rate
ssl-connections rate
mgmt-traffic rate
mac-miss rate
inspect-conn rate
acl-memory
regexp
syslog buffer
syslog rate
b)Should be able to report on the following statistics:
Load average
Processes
CPU states
Memory usage
c)ACE Count for FWSM--Need to report/display on ACE count per FWSM context
Waiting for reply...
Thanks & Regards,
Shanti Ranjan Dash
David Stanford Fri, 11/30/2007 - 06:49
  • Cisco Employee,
This isn't a quick one or two line answer due to the amount of objects you are looking for. You'll want to read through the following MIBs to see which info you want:
CISCO-PROCESS-MIB
BRIDGE-MIB
CISCO-SYSLOG-MIB
CISCO-IPSEC-FLOW-MONITOR-MIB
CISCO-MEMORY-POOL-MIB
Not everyone one of these counters has an snmp object also. For example, there is currently no object for xlates.
