LMS installation in separated partitions
Answered Question
Nov 16th, 2007
Hi everybody,
I would like to know if is it possible to install the LMS 2.6 in separated partitions in a Windows server: one for the application files and directories and other for the data and logs.
Thanks.
Correct Answer by Joe Clarke about 9 years 2 months ago
This is not possible. Everything must live under the same NMSROOT directory initially. Once you have things installed, you can choose to move certain things to different directories (i.e. syslog.log file, device configurations, software image repository).
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 11/16/2007 - 08:13
