WLC - Layer 3 Wired guest lan ?
Nov 16th, 2007
Hello
Has anyone been able to do this with a WLC, configuration guidlines say :"
"Wired guest access ports must be in the same Layer 2 network as the foreign controller."
Anyone know if Cisco is working on making this solution work on L3 aswell ?
Gk
scottwilliamson Fri, 11/16/2007 - 08:00
Hi gudmundurk,
I'm not sure if they would consider it worth developing as you would have to create a tunnel between the guest vlan's gateway and the subnet that the controller is on to keep your network secure anyway. Unless someone out there knows..........
Scott
simon.dwyer Thu, 07/14/2011 - 22:48
I can see this being useful if you have a VRF setup on your network for guest access on your network.
I am trying to work this out myself as my WLC sits in my datacenter and i use a VRF to handle guest access so i cannot give them L2 to the WLC.
Trending Topics - Security & Network
