AA on 2811 with an internal DN
Nov 16th, 2007
Hi, I'm actually using IPCX to "play" the corporate AA, and I would like to use my 2811 as a backup of that primary AA. If the RP of my primary AA is unable or busy I want ccm transfer the call to an DN hosted by my 2811. How can I do that ? Does somebody have a tcl that already do that ?
Thanks !
paolo bevilacqua Fri, 11/16/2007 - 05:12
  • Hall of Fame,
    Founding Member
hi,
This is B-ACD / AA for cme. search for that will be pointed at the documentation. It can call any number, not just ephone under CME.
paolo bevilacqua Fri, 11/16/2007 - 05:22
  • Hall of Fame,
    Founding Member
It should. But even if some dependency comes out, just set a minimal cme config that doesn't do anything.
