After power outage the software of Unity 4.X
jason-calbert_2 Fri, 11/16/2007 - 08:44
  • Bronze, 100 points or more
Check to see if the service AVCSMGR is started. If it is not start it. If it does not start look in the event viewer to try to see what the cause is. You should not have to reload Unity Thanks
Jason
