Richard Burts Fri, 11/16/2007 - 07:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Youssef
One cable will bring up the connection and will pass data. Two cables will allow the data to pass at full rate. So it is enough to have one cable but it is better to have two.
Rick
Pavel Bykov Fri, 11/16/2007 - 09:03
  • Silver, 250 points or more
In term of marketing bandwidth, you will get 16Gbps with one cable and 32 gbps with complete circuit, i.e. two cables in your case.
If you have E-series, it's 32Gbps with one and 64 with 2.
Hope this helps.
m_zabetian Fri, 11/16/2007 - 09:47
It is work with one cable but two cables you have redundancy and double bandwidth
