cheat sheets???
Nov 16th, 2007
i'm am currently doing my ccna & ccnp classes for my certification's, but i'm having problems remembering all the switch/router commands for programming them. I didn't know if there where cheat sheets for these commands that way i could use for studying and have for my notes. Any help would be greatly appreciated!!
Overall Rating: 2.5 (2 ratings)
guruprasadr Sun, 11/18/2007 - 21:40
  • Gold, 750 points or more
HI, [Pls Rate if HELPS]
Refer the Attachment (.zip) for CCNA and CCNP CISCO Press Command Reference Manual.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Danilo Dy Wed, 12/19/2007 - 08:23
  • Blue, 1500 points or more
If you have access to a switch or a router. Practicing the commands is better than memorizing them. It's like writing them at the back of your hand
Else, you can use Dynagen http://www.dynagen.org/
Dandy
